I finally got my vag com working. The problem was with my brothers labtop. I took my desktop into the garage and it worked fine. So now I want to get keyless entry. Do you need the vagcom to program the keyless entry? I have a 99 1.8t. How do I program the keyless entry? I assume ill need the remote first. Thanks.
6th Grade
It is easiest with the Vag-Com.
Group 46
Adaptation channel 0
Yes, you want to clear all
Adaptation channel 1
Enter the number of remotes you have that you want to program to the car
After hitting "save", press a button on each remote. You'll get a chirp of the horn for each as you press the buttons.
Thanks I just have to order the remote now. Also, do all 99 1.8ts have the reciever for the remote? Is there any way to check to make sure?
