1 - 9 of 9 Posts
My mother recently got a new Caddy SRX, she just called me with a complaint. She says that the truck doesn't have power steering and it's hard for her to turn while parking. I went and tested it out, the power steering is working fine, but it's just harder to turn than the Eldorado that she's used to. This truck has a big V8 so I assume the heavy front end might make it harder to steer.
Is there anyway to increase the power steering, make it easier for her to turn the wheels at low speeds? Different fluid? Something?
The SRX - like many other GM's - have Magnasteer, an electric p/s pump. It is the primary complaint of new GM owners.
Have her check with the dealer - there are several settings available that can be changed, at least on my uncles DeVille it was.
Discussion Starter · #7 ·
Thank you sir, I'll tell her to call the dealer if you think they can help (I figured they couldn't do anything). I'll also check the tire pressure.
I'll also beat the living shit outta her for not testing out how the vehicle steered at 2MPH while she took it out for a test drive :roll:
but go easy. she's your ma!
1 - 9 of 9 Posts
