Car groan rubber on rubber noise from column only when I turn to right; thought it was fluid and i put in the wrong fluid, so this weekend i will flush and look at susp. joints. But, the wrong fluid didn't change anything. ? If it only happens when I turn to right this doesn't necessarily mean it's the right wheel; could be part of left wheel doing all the groaning. This happened all of a sudden after a drive on a sandy beach, but don't let this throw you off the trail 1.8t 2000 tip Two clues: Only happens when I turn to right and noise groans rubber on rubber noise coming from column with effort in slow driving turns????
Discussion Starter · #2 ·
I sprayed the susp. joints with wd40 and notice a lot lesss moan and groan; maybe the drive on the beach kicked sand up into them and made a "dry" socket in the joints
Did you spray the bushings or the ball joints? If the noise was from the ball joints (or tie rod ends) they should be replaced.
WD40 IS NOT A LUBRICANT. It is a combination of solvents that dissolves old, gunked-up oil and then evaporates. Use it to clean gunky parts or to re-liquify oil that has turned to goop. DO NOT USE IT TO LUBRICATE PARTS.
when i had my creek, i pushed up and down and heard it to see what side it came from.
narrowed that down then tried to see if it was top or bottom.
then poked a hole in the rubber and with a test light, then used the hard plastic spray hose and sprayed white lube and when the noise went away i knew what had to be changed:)
