im trying not to be vaig here i have a 99 passat(b5) and i was setting up neons in the car so i intercepted the ciggarette lighter in the trunk to get power so i was doing the wiring and all of a sudden my power doesnt work... so i check the fuse box and its fine and i check to see if i short wired anything and i didnt i was wondering if anyone could help...i thaught it was an inline fuse but my auto shop said they usually dont do it but then again it is a VW
the neons are like 2 amps barely i think most neons are the same
and i tested all the neons after i put them in its the ciggarette lighters is whats pissin me off
Wire diagram for 99 shows more than one fuse. There is a 15A fuse for the cig liter in the dash, and two 20A fuses, one for each power outlet. If your 99 is like my 01.5 the rear power outlet fuse is in its own in line carrier behind the the relay panels. Also check the ground connection.
