My 2001.5 Power Outlet in the Back has gone out. Checked the fuses, they were ok. I even took apart the center console to check the wiring, it looks fine and I just cannot figure out how to get it to work. Are these things known to just go?? Has anyone had this problem before and fixed it?
Which fuses did you check? They aren't in the side panel, there are two yellow 20A ones above the pedals, You need to remove the lower dash to get to them!
And I'd wonder why they blew if you aren't using that outlet. Make sure there aren't any shorts in the wiring leading from the dash to the trunk.
Thanks for the info... I shorted it out I am pretty sure... I replaced the fuse and it still will not work... I had a phone charger in it... cant be sure if that is what caused it though
