I've posted that in someone elses thread earlier, but i probably should have started a new thread to receive more answers. so here we go
2001.5 passat 1.8t, awm, auto tranny, sedan, 190k miles
Underwent Unitronic Stage 2 software update around 6 months ago
would a faulty TC ...F-O-R ....S-U-R-E... throw a code? after all it is just a mechanical part, without anything electrical to it so how would the ECU know that there is soemthing wrong with it?
i mean, i've researched TC and nowehre it says that if a TC is faulty you'll get a code, but rather some type of relay inside of transmission, solenoid or whatever.
im asking because my transmission has been slipping recently on acceleration. it loses its grip around 4000rpms on 2nd gear, rpm's go up because im pressing on the pedal so rpm's keep going up without any acceleration , like on neutral (it all heppens very quickly) and tranny shifts to the next, 3rd gear, and the story repeats itself from 3rd to 4th. On both shifts the car jerks a lot, oftentimes the transmission locks in one gear, all of the marks on the cluster (P,R,N,D,4,3,2) light up and i have to restart the engine to reset it. I've also heard that it's sort of a defensive system that prevents the tranny from breaking completely. It is not low oil because i've checked that already and it is fine
This is why i was suspecting torque converter after all the research i've done but i dont have any codes. TC throwing a code is only talked about on this forum, i havent found that information on many others. As a matter of fact, other forums say the opposite. Could you guys confirm?
· Moderate Moderator
Clutch packs will slip if there isn't enough hydraulic pressure applied to them. Keep slipping them and they'll get damaged quickly.
Scan the TCU with VCDS.
Check trans fluid level.
Lockup torque converters have electrical actuators. Some trans systems watch rpm of several different things and can detect slip.
Sent from AutoGuide.com Free App
As Steve says, clutch slip will log a fault. He mentioned the TC lockup clutch, but that is intended to lock while cruising, not under hard accelleration. So I wouldn't blame the torque converter, in your case the slip is probably due to clutch packs in the transmission case, and I'll bet the damage has been done. By the way, a 190,000 mile automatic transmission and high boost are usually not a recommended combination.
Discussion Starter · #6 ·
i have changed the fluid with filter twice in the past
magnets had a good amount of gunk on them
well if you guys say that it wouldnt be a TC, car will most likely go for parts :thumbdown
but i will send it to a tranny mechanic and see what he says
