1 - 2 of 2 Posts
Hi All,
So I just replaced the regulator clips for my front driver side window. While I was in there, I noticed you can get access to the inside door panel with minimal obstruction.
I have some dents in the front passenger door I want to try and pop out from the inside (where the regulator is).
My questions:
1) Will I have the same access on the passenger side?
2) Can I take out the regulator panel with the window attached and fully down? Or should I remove it first before removing the panel?
Thanks in advance.
Dan
The access should be almost the same as for the drivers side, the parts are virtually mirror image in design.
1 - 2 of 2 Posts
