1 - 16 of 16 Posts
Finalyl after my recovery from busted CV boots/joint, busted middle finger from the Zender rear lip install, I decided to take some new pics of the ride.
Offset - 32mm front and 30 rear. Rear will be 20mm once I get longer wheel bolts.
Now, just wish I had an extra $3-400 to repaint the RS bumper
More things to come would be the Spec Stage 2 clutch, light flywheel, and some other go fast goodies. So, check the current mod list HERE
Thanks everyone
Wheels are 18x8 Axis Speed 6's with 40mm et.
Suspension is KW V1 Coilovers
Tires are 225/40 Yoko AVS ES100's (run wider then the basic 225 series tire)
H&R 8mm spacer in the front, custom 20mm spacer in back (2 10mm custom spacers together)
more to come though, so stay tuned :thumbup:
Discussion Starter #11
Thanks, I lovethe color too. Wish that I could afford a complete respray. There is some type of scratch or dent on just about every body panel. Just cant afford it at this point tho.
Royal green is the best, not my favorite Passat color though.
Steve
Discussion Starter #13
Thanks Xedo
It depends on the type of tire that you run on the car. For me, the Yokohama's run wide so they stick a little further out. 32 in the front is fine, no issues yet. 20mm in the rear for me rubbed slightly but not enough to concern me much. Only rubbed on the outer edge slightly.
Steve
Scuba2001 said:
*sniff sniff*
I smell a big brake conversion!
Nice stuff man..
1 - 16 of 16 Posts
