Well, my new variant just reached 5k, so after reading these forums, I decided to "do-it-yourself" with the NAPA 1333 Big Kahuna (and a Syntec blend 5W-30) instead of going to a quicky-lube. I just went with conveniece for the first time around, and got the filter at the NAPA distribution store just up the highway for under $14.
The job will go much quicker next time, now that I know where everything is, including how to remove the belly pan. There was no way I could've reached the oil filter from below, so went from up top. You can see the radiator overflow container pulled back.
The original filter was part 06A 115 561B which I understand is the newer, larger OEM filter for the 1.8T, but it still was way smaller than the Big Kahuna. Someone under another topic said they measured the volume difference at 1/4 quart--I'd say it's gotta be at least that much if not more. The fit isn't alarmingly tight. It was easy enough to thread it. There is some room to maneuver.
But, in general, getting my arm down there was difficult. The original filter was on very tight, and it took alot of work using a strap-type filter wrench to get it to budge. The fittings on the tube across the opening, which I was afraid to try and disconnect, and other adjacent pieces scratched my skinny arm to pieces.
When I was done, I tried and discovered that there is not room to get my strap-type filter wrench around the Big Kahuna, so I'll have to get a different wrench type, and buy a 4 pack of Wix 51333 now that I know this thing works.
Well, just thought I'd share.
