141 - 160 of 610 Posts
"sluts bend over further" I think? Grandparents were Pennsylvania Dutch so not exactly sure if thats the direct translation!!!:thumbup: Do you think the plotter shop would be willing to make something else up? If so, maybe an email address? Thanks friend!
Discussion Starter #142
Sirs
Yeeeeee-Haaa
15.000 views.I feel honoured.We should talk about this donating-per-click thing.....:lol:
News from the otherside of the pond :
Replaced my rear Aero twin by a full-covered wiper, coming from the Skoda Fabia:
Wiper: 6Y6 955 707 11,80€
Blade : 6Y0 955 452 5,65€
Cover : 6Y6 955 435 2,30€
Yes, it´s still the wrong resting position.Didn´t found a right laying motor yet.
Hatch spoiler, Zender VWA concept:
After installing the spoiler, i had to shorten the wiper.Luckily, it´s not visible :)
Sticker on my third stoplight, glowing up while braking:
means as much as : Brake! Asshole! :)
Latest mod:
12pcs set butcher´s plate "Emden"
Meyle HD control arms and tie rod ends 335€, costs for installing them 280€ :cry:
Oh, not to forget the outer "rubber bags" of the driveshafts again :mad:
Thanks for looking.
Comments / replies are welcome :)
Discussion Starter #146 (Edited)
Under the hood mods
Sirs
Lashing eyes chrome /chrome
Unnecessary but nice
Coming from Audi RS6 / VW Bora Highline
1J0 864 203 D ZZ, 12,37 € each
Say hello to Mr. Cool(ant cap) :lol:
Comes from Audi R8 and adds further 10 hp :lol:
ETKA No.: 420 121 321, 52,90 € :crazy:
Little modifying needed to lock in the right angle.No problem.
Because i was pissed of the missing lighting under my bonnet, i designed an own one by using
a) A prefabricated, self adhesive LED strip, 30 LED´s, 60 cm (availiable on ebay)
b) auto level switch ( bought at the German "radio shack")
c) VAG housing
1x 1J0 972 923 0,88€
1x 191 972 712 2,32€
VAG Wires
1x 000 979 133 (1,0 mm²) 1,52€
1x 000 979 129 (1,0 mm²) 1,52€
d) own made holder, from a piece of alloy (10x25mm), folded and sticked with "bond and seal" under the bonnet
Soldered switch with wires and shrinking hose:
added housing:
fixed:
You can see the switch carrier in the upper right corner
The switch is fixed with a tie rap at the carrier
The result:
Prince of the light :p
When opening the bonnet, the led strip lights up automatical
Power supply lead off from the battery.Of course with a fuse carrier and a 7,5 Amp. fuse (hidden in the battery bay).Ground supply at the bonnet beneath the noise absorbing mat :wrench:
Discussion Starter #148
How hard was installing the Auto Dim mirror? I've been searching for one with the ambient lighting for a bit.
Sir
Very easy, but i have to confess that mine is the "poor solution", which means that it´s only dimming (no re-dimm function when driving backwards).This is O.K. to me.
For this kind of installing you only have to connect switched ignition and ground.
You have to obey that there are two versions which are not interchangable.
With rain sensor and without.
Discussion Starter #149
Sirs
Lord of the light :)
Changed from the dark side to the bright side:
HID 6000K:
Because HID´s are illegal in Germany i installed a pair of fake jet washers, by applicating painted washer caps onto the bumper :whistle:
(Picture will be forwarded when avaliable)
Zee German
I think this is illegal, too. ;)
(§ 49a Abs. 1 StVZO)
"Die dritte Bremsleuchte darf - wie andere Beleuchtungseinrichtungen - nicht verdeckt sein - auch nicht teilweise."
But it looks good.
:cool:
Discussion Starter #153
But it looks good.
:cool:
Hehe.
Manchmal muss man was offensichtliches hinwerfen, damit die Leute mit den Fan-Fahrzeugen von Werder Bremen nicht anfangen zu suchen :lol:
Discussion Starter #156 (Edited)
Sirs
The ordered parts had been delivered and are built in:
I call it the < How to avoid the "what´s the time dad" question > mod:
Sharan watch (with auxilliary heater function)
Watch: 7M3 919 203 Y20, 60,80 €
Housing: 6N0 972 705 1,58€
Wires: 000 979133 (x3) 1,65€
Front frame: 7M0 867 659 Y20 4,25€
Rear frame: 7M0 867 660 2,20€
prices incl. VAT 19%
For the "greenies":
Watch also availiable: ETKA No.: 7M0 919 203 D Y20
Unfortunately the contol buttons are not lightened :(
Write up located here:
http://www.passatworld.com/forums/showthread.php?p=2191388#post2191388
I´ve got two further mods running :lol:
Stay tuned.........:wrench:
Discussion Starter #159
Sirs
After i bought a used glove box in stock last year, i processed an outstanding mod to it.
Can´t wait to get your feedback on this extraordinary mod.
Sirs
Hey.You didn´t really thought that this was te whole story, did you?
Stickin´ a pissy badge is not really something i would call a mod :p
As mentioned, i purchased the glove box last year to have it in stock, for potentially repairs.
Because i had some free time between 21.12/06.01 i decided to dissamble the whole unit for reinforcing purposes, to avoid futurity damages.
While doing this, i decided to remove a further weak point :The lighting.
The OEM lamp was removed, and the originated hole was closed by a piece of tin, which is used now as a micro switch carrier (found one at our inc., originally used for fire protection flaps)
An actuator also had to be installed:
5mm studscrew
Actuator:Check
Switch:Check
Lights:???????
Here we go:
24 holes for 24 LED´s (white,5mm,10k mcd/20° Radiation angle), soldered together in 6 groups of 4 LED´s.
Each group downstreamed to one resistor of 100 ohms /1 w
Tadaaaaa:
..........and i said:"There will be light!"
Not ready yet! :wrench:
Stage 2: ;)
Cupholder lighting: :crazy: :lol:
6 x same LED´s as before, assembled in 2 groups of 3 LED´s downstreamed to one resistor (each group) of 270 ohms / 1w .
Looks like this:
BTW:The power supply was processed too.The gloveboxe´s light, lights up now when opening, without the need of actuating the light switch (something i was nerved of)
Ready?
Not really.Soldering iron had been warmed up one time so.............
Stage 3
There had been two LED sets left over from my door-handle modding, http://www.passatworld.com/forums/showthread.php?t=264728
,and profuseness is a sin :lol:.
So i drilled two wholes into the gloveboxes lid.Left and right beneath the handle and stationed those LED´s there.
front sight:
May i ask :
About this Discussion
143 Participants
captainfantastic
Volkswagen Passat Forum
Passatworld is a forum dedicated to Volkswagen Passat enthusiasts to discuss mods, Quattro, Turbo Diesel, reviews and more!
Full Forum Listing
