OKay, I've got all but one of the crome pieces for the front, and I've got old side marker lamps that I could re-install, but I just haven't yet. I wasn't planning to add the Mach 1 or Boss 302 graphics, because I really don't like them (if I had a 65-68 I'd for sure add the GT stripe, but the 69s have enough "flair" to get by without).
The seats are cloth Recaros that came with the car, very comfy and lots of bolstering.
The engine is a 302 that the previous owner put in (along with a 5 speed out of a fox body (T-5) and 9 inch 3.55 traction lock rear end. I rebuilt the top end of the engine (it burnt oil that I determined was valve stem seals), replaced the stock heads with heavily ported 351C heads (1.90 int 1.64 exh), replaced the cam (it was a torquey Comp Cams) with an Edelbrock Performer RPM (Adv. Duration: Int/Exh 290°/300° Duration @ .050'': 224°/234° Lift .490/ .510, Lobe Seps. 112°), to match the Performer RPM intake manifold, Holley 650 CFM carb, 1 3/4 inch equal step length Tri-Y headers, 2.5 inch dual exh with crossover going back to two Flowmasters. It revvs to about 6500 rpm, hasn't been on the dyno, but if you can believe Edelbrock, then it should put out 350 hp at the flywheel.
I also added a later model mag pickup ignition with wide cap adaptor and MSD 6AL ignition (MSD is the bomb, that multiple spark stuff really works, the car went from smelling like a refinery at idle to purring like kitten and no more gassy smell). Most recently I have rebuilt the power steering control valve, replaced the master brake cylinder and added a manual proportional valve control. Next is to replace some of the 10 year old aftermarket springs and shocks, it rides okay, but they are getting ugly.
