i have a passat 2002 1,8T.
does anyone have any pics of their exhaust system.
I think that the guy that had my Passat before me have removed the "cat". Isnt it suposed to be installed between the front seats?
Those of u that have a front monted IC, what have u done with the sensor that is located on the intercooled??
Open your hood.
As you look at the left of the engine, you'll see the exhaust manifold/turbo you can clearly see the CAT as the first section of piping running after the turbo. (the stock pipe is very fat) (It should have 2 O2 sensors attached to it) Followed by the Downpipe, then the Resonator, lastly the muffler, and tips.
What sensor is located on the stock SMIC? I missed that! :nervous:
You have a bung welded onto the ic pipe that has 3 holes. One for the sensor itself, and 2 tapped to screw it on. You will also need a 1" od nipple on the other side for the DV.
