1 - 3 of 3 Posts
I've been looking at the manual's installation instruction and i'm not sure i like the way the PhatBox sticks out the side compartment (which would involve cutting a hole into the door) so I've been thinking about an alternate location or way to hook it up. If you can please post pictures of your phatbox setup
My intake has Emphysema
First off, there's no need to cut any hole for the PB if you instal it correctly. Also, another hole can be drilled into the mounting plate to move it in further, OR just do the cable mod if you're not comfortable with the preasure on the connector. (it never effected mine).
I took mine from the cubby though since I put a sub enclosure on that side and mounted the PB on the back of the seat. Eventually, it will either go under the rear deck or I'll get rid of it completely for a USB flash drive for my HU
1 - 3 of 3 Posts
