TJ, your right about the pcv valve(its location at its possible breakdown). But the fact that WEEn2004 found iol in the secondary pcv valve, is proof that the other(primary valve) is not leaking, plus he would see evidence(oil) arounf the area slose to the oil filter. ALTHOUGH it would be wise to check it.
as far as it feeding the boost, im positibve that the pcv doesnot effects directly the boost. the only way it would matter would be if the pcv system would get clogged up and the mottor could not breath. then allot of other internal parts would be at danget(specially with that much boost)
and to answer your question wen2oo4: the boost gauge is supposed to run on a vacum(around 17-20 in/hg)when parked, even oftentimes under normal driving conditions(anyone w/ a boost gauge can acount for that). the gauge only rises over 0 psi when the boost is working under a load(thats the Boost).
you say that it drops when you hold it at 2k rpm....sounds like a leask to me, at if the gauge drops that fast, it just might be the tubbing to the gauge,....
alltogether, im starting to think its the boos gauge or the connections that might have a flaw.
this is a tough one(just by reading the symptoms), but i hope this helps a but.....
im not a pro, im actually fairly new to the Turboo world, i previously own(still own) an acura integra, it has 235k miles on it and still drives like a champ! its droped,w/camsfull exhaust...(its fast!), i still redline it when i get inspired it, and i've been the only one to lay a wrench on it, (just so you understand where im coming from) i speak from what i've researched in the B5 and work that i have allready done to my b5.
anyways...laters :b5:
ALfredo
