1 - 12 of 12 Posts
I had already picked up bosch 315cc... will the spray pattern effect performance or just a stable idle
If your performance improved after installing those injectors, great. But I don't believe the dual spray pattern is a valid argument for our application. With a three valve intake port, a dual spray will still hit the port wall. You would need 3 spray cones to line up with the 3 valves.
It's better than a fire hose.
Click the videos of injectors in this link. No matter what you get better atomization. These are not off the shelf generic injectors. They are designed to work with VW/Audi engines.
http://www.usrallyteam.com/injectors.html
1 - 12 of 12 Posts
