No they wont fit without an adapter.
Passats wheel bolt pattern is 5x112, the centre bore is 57mm and the wheel bolts are 14mm.
As far as i can remember the polo only has a 4x100 bolt wheelhub and the bolts are 12mm (correct me if i'm wrong, i had a polo as my first car 14 years ago).
I think the Passat wheels are only interchangeable with the Audi A4/6 range and the new Golf.
Thanks for your answer.
The Polo I'm talking about is 1 year old, it's the last one, and it uses 5 bolts, but... Are there any kind of adapter to fit them in case of different bolt pattern?
I would imagine then that your wheel bolt pattern will be the same as the golf/bora/TT 5x100, i have seen adapters available for the golf's and TT's but they are quite expensive, can't think from the top of my head where i have seen them listed for sale.
What Passat wheels are you after, as the wheel bolt pattern you have must open the field up to a vast range of alloys?
