1 - 11 of 11 Posts
FWD Passats have a torsion beam only; 4Motions have a rear 14mm bar. I believe wagons and sedans are the same.
The front bar on the wagon is 2mm larger from what I have heard. No difference in the rear setup. You will love the rear bar.
why is it that Eibach only do a front Sway bar for the B5.5 ?
I had a Neuspeed 25mm RSB on my Bora and loved it :thumbup: .
Having just got my B5.5, i was considering going with both F + R sway bars, but eibach only do the front ? I would have thought that this only leads to an increase in understeer :crazy:
Neuspeed ARB's are hard to get hold of in the UK :thumbdow:
rcassidy said:
A FWD 1.8T Wagon DOES NOT come with any rear sway bar..... Just an FYI
Ryan
Ditto this. I have an aftermarket (Neuspeed) rear sway bar installed. Its :thumbup: :thumbup: :thumbup:
The FWD setup has a tortion beam rear suspension, the after market sway bars just further stiffen this beam.
The 4motion cars have drive shafts back there and don't use a torsion box so they need a sway bar to have the same effect.
At the risk of sounding like a broken record, read the vwvortex McPherson strut thread before making a single ended modification.
Don't listen to the broken record. We do not have McPherson struts. Drive a Passat with a Nuespeed rear sway bar and you will not want to give it up.
1 - 11 of 11 Posts
