Hello.
Greetings from me since i`m new to passatworld.
My problem is that when using A/C it`s dripping water out somewhere very unusual place but not where it should be and causing to wet passenger side floor.
Using climatronic system and car is 2002 B5.5 wagon with 1.9TDI 96kW manual.
Added also a picture from where the water is leaking.
The orange circle in the back right is the place where water is leaking. Thinking that it comes somewhere higher?!
It`s location is under dashboard, in the middle, but more to the passenger side near the lower vents.
When A/C is turned on it`s leaking and using ECON it`s not, obviously!
Tried also different air directions: to windshield, to the middle and to feet.
What i saw that it`s leaking more when the air is directed to windshield
What i`ve tried to fix the problem:
1. Found the a/c drain on the firewall and cleaned it from the engine side. Took out the rubber and it was OK!
2. Interior side plastic tube also is NOT filled with some dirt, so the problem is not there also.
3. Two holes under battery box are clean
4. Seal under ECU and cabin filter are good, since i resealed them and tested with rain and it`s OK!
So as you see the problem is not coming from outside but inside.
I´ve googled ALOT! to find a solutions but came up empty handed.
Only one problem with the same place leaking water but it was the fault of cloaged A/C drain plastic tube.
So my question is, that what might be the problem for that unusual leak?
1.Is the HVAC box somehow clogged inside and if so what could be the solutions and is it DIY?
2. Could the problem be in some of the A/C tubes located under the dashboard in the middle. Broken or some of the rubber seals gone bad?
3. Something else?......
