1 - 1 of 1 Posts
Hello to everyone.
Does someone know if its possible to somehow make a adaption or coding on the D6 - Trunk elect. with the VCDS?
Problem is that I would like that the electric trunk would work with the trailer attached.
If I attach the trailer lights socet then the tailgate opens the lock, but does not go up. I tried to do adaption, but it seems that it does not work on this module. Tried the security code 12345, but still no luck.
Also in the ross-tech page it sais that "This control module does not support Coding."
VW Passat (3C) Trunk Electronics - Ross-Tech Wiki
Maybe someone knows if it is doable?
Car is a Passat Alltrack b6 from 2014.
Thank you!
1 - 1 of 1 Posts
