I have replaced my water pump and timing belt once before with no problem. I am not an experienced mechanic, but I am learning. I got myself into a bind this time and I really need some help.
Recently, I needed to replace the water pump and had to remove my timing belt. I used the camshaft locking bar to align the camshafts and also used the clamping bolt to assure that the crankshaft didn't move from TDC. I had no problem replacing the water pump, but ran into significant problems getting the timing correct. I have taken the timing belt off 4 times and reinstalled it. Each time I get an error for bank A for the camshaft position sensor and cylinders 1,2 and 3 are misfiring. The engine is running really rough at idle.
I don't know what I did wrong. The locking bar fit on the camshafts correctly and I following the detailed instructions carefully.
The last time I removed the timing belt I also removed the value covers. I put the camshaft locking tool on to keep the camshafts in alignment. The right side (drivers) camshaft notches align with the arrows (near the chain). On the left side, the camshaft notches are to the left a few degrees of the arrows. If I turn the exhaust camshaft clockwise so the camshaft notches align with the arrows, the camshaft locking tool will not connect between the two camshafts. I didn't think this was possible!
Did I really screw this thing up somehow? Can someone help? I don't know what to do. Help!
