hi everyone i have many problems with my car and i need help please as i do not know what to do i already changed Transmission Range Sensor (F125) and change oil for transmission as well but still car go in limp mood once i move from P to R and dashboard PRND432 ALL RED then i move the car to N i switch car off and after switch car on i drive on D normal but there is big delay in shifting 1st to 2nd can be 4000 rpm i checked DTC no damaged or water.
the car using high fuel as well and acceleration is not good as it should before, tiptronic when car is not in limp mood works.
The car is 1997 1.6 AHL manual
Tire Automotive parking light Wheel Car Vehicle registration plate
amended to 2002 tiptronic 1.8t full car transferred into it
please any advise or help
Friday,07,January,2022,17:24:35:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.2.0
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ3BZ3P054414 License Plate:
Mileage: 69990km-43489mi Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ3P054414 Mileage: 69990km-43489miles
Address 01: Engine Labels: 06B-906-018-AWT.lbl
Part No: 4B0 906 018 DH
Component: 1.8L R4/5VT 0002
Coding: 11551
Shop #: WSC 00028
VCID: 6ADB77AF167FE0D6AD-5178
WVWZZZ3BZ3P054414 VWZ7Z0B5445138
6 Faults Found:
16955 - Brake Switch (F)
P0571 - 35-10 - Implausible Signal - Intermittent
16500 - Engine Coolant Temp. Sensor (G62)
P0116 - 35-00 - Implausible Signal
17925 - Power Supply Relay for ECU
P1517 - 35-10 - Electrical Malfunction - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - Intermittent
18036 - Powertrain Data Bus
P1628 - 35-10 - Missing Message from Steering Angle Sensor - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 DD
Component: AG5 01V 1.8l5VT RdW 1314
Coding: 00103
Shop #: WSC 00028
VCID: 72EB6FCF3EAF281615-515A
3 Faults Found:
17090 - Transmission Range Sensor (F125)
P0706 - 35-10 - Implausible Signal - Intermittent
17087 - Brake Switch (F)
P0703 - 35-10 - Electrical Malfunction - Intermittent
18171 - Shift Lock Solenoid (N110)
P1763 - 35-10 - Open Circuit - Intermittent
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 00000
Shop #: WSC 00000
VCID: 25414493BFE10FAE40-515A
4 Faults Found:
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
01424 - Yaw Rate Sensor (G202); Reference Wire
57-00 - Electric Circuit Failure
01423 - Lateral Acceleration Sensor (G200)
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0005
Coding: 17000
Shop #: WSC 00028
VCID: 285F4DA7C8F312C67B-5178
4 Faults Found:
01296 - Sensor for Vent Temperature; Center (G191)
30-00 - Open or Short to Plus
01271 - Positioning Motor for Temperature Flap (V68)
37-10 - Faulty - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
01299 - Diagnostic Interface for Data Bus (J533)
79-00 - Please Check Fault Codes
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 08 AIRBAG VW61 04 0001
Coding: 12344
Shop #: WSC 00028
VCID: 24475997B4DBF6A657-513C
5 Faults Found:
01588 - Igniter for Head-Airbag; Drivers Side (N251)
32-00 - Resistance Too High
01589 - Igniter for Head-Airbag; Passenger Side (N252)
01217 - Side Airbag Igniter; Driver Side (N199)
01218 - Side Airbag Igniter; Passenger Side (N200)
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 927
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 05415
Shop #: WSC 00000
VCID: 62CB1F8FEE4FB89665-513C
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01330 - Central Control Module for Central Convenience (J393)
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: 70EF65C730A31A06E3-513C
2 Faults Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 6T Komfortger?t HLO 0001
Coding: 00258
Shop #: WSC 00028
VCID: 366393DF12477436F9-4B32
Subsystem 1 - Part No: 1C1959801
Component: 0Z T?rsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802
Component: 0Z T?rsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811
Component: 6T T?rsteuer.HL KLO 0008
Subsystem 4 - Part No: 1C0959812
Component: 6T T?rsteuer.HR KLO 0008
6 Faults Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
00947 - Trunk Lid remote Control Switch (E188)
29-00 - Short to Ground
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
00931 - Locking Module for Central Locking; Rear Right (F223)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 D
Component: RADIO SON 0004
Coding: 04403
Shop #: WSC 00028
VCID: 2643439FC2E704B649-4B18
2 Faults Found:
00853 - Loudspeaker(s); Rear
00856 - Radio Antenna
End-------------------------(Elapsed Time: 04:46)--------------------------
I would clear all the codes and then see which ones come back. That's a long list and it's hard to believe they are all still valid.
How did you change the fluid? There is a special procedure that needs to be followed and it's not the same as many cars.
How many miles on the transmission? Did you put in a new or re-built torque converter when it was installed?
Did this start suddenly or has it been getting worse? Any other history on the problem?
i cleared the codes but still have the brake switch, transmission range sensor even after i changed and clear code.
yes i follow instructions as it should be as i watched many videos on youtube for many specialists and i took out the pan out clean it and clean filter as i could not find new one.
the car has very low miles only 69990km-43489mi.
I did not put anything in the car except front electric heated seats and 2 wing mirrors with welcome lights and indicator for skoda superb.
this start suddenly after the electrician install the dashboard and floor carpet and rear lights but before when the mechanical fished his job the car was perfect as i was driving it before in London as i cut the car there and the harness and door dashboards was complete.
i forgot to mention one thing ESP sensor is missing.
we amended the brake light switch as the car was RHD but Egypt LHD. and almost the full harness some wires extended only but did not cut any wire.
thanks for your reply
So, this was a LHD conversion from RHD? Did you already check the connections fuses related to the TCM? Sounds like a lot of areas where something could have gotten pinched or cut during the conversion process. If this was an un-modified car, It would be easier to tell you where to look next, but there can just be so many variables in this case.
If this did not have any problems UNTIL the "electrician" was doing their part, then I would consult the "electrician" for assistance.
Reactions: KHedges
