1 - 3 of 3 Posts
Any idea what may be the most the likely causes.
I had new coils put last month by dealer as they had call back on them.
Also, I am still under warranty. Will this be covered.
Any help will be greatly appreciated.
Thanks
Khurram
Have you looked up the definitions for the codes yet?
IIRC the P0300 is mult cyl misfire, and the P0303 is gonna be a cyl 3 misfire.
my best guess is coil packs, make sure that when they were replaced they used the most updated packs. If you want to, switch the cyl 3 pack w/ 1 and see if the misfire follows...if it does its the pack if not it could be a spark plug giving you issues.
That happend to me on my 98, the coil packs are great, but I had a leaky valve gasket causing my cyl 4 plug to be so cruded up I was having huge misfire problems.
1 - 3 of 3 Posts
