That haze is a light surface scratch for dirt getting under the bra and rubbing against you hood. You need to get some Mothers California Gold Scratch Remover. http://autogeek.net/autogeek/motcalgolscr.html
Depends on the orbital and the pad used wether it will be effective or not. If its a $19.95 one from WalMart and the pads that come with it it will be a struggle. If you have a Porter Cable and a yellow pad from Lake City then your on the right track .schmove said:Is scratch remover different from the polishing I did using 3M IHG and Einszett Paint polish with an orbital buffer? I did like 5 applications and there's still a haze.![]()
Check the auto parts stores that sell body shop supplies too .. There is a few others out there that will remove it but a lot are full if oils or fillers and just mask the job. Meguiars ScratchX will do in a pinch but once you feel your happy rub the area down with a 50/50 mix of rubbing alcohol & water to remove the oils and fillers then look at the spot. If your happy wax over it .. if not .. keep buffing.schmove said:Thanks for the great info! I was hoping you'd chime in. Is the Meguiars DACP #83 readily available at local auto store places? Or is there a comparable one that is?
