I have this code that keeps coming up on my car. It is P2181. I posted about it a while back when I replaced my coolant sensor.
As it says in that thread changing the temp sensor seemed to work for a while but now the code is back. I bought a device called an ELM327 bluetooth adapter on eBay for $15 and an android application called Torque for $5 (thread about that here). I used those things to read the freeze frame data. Here is the info:
Freeze frame information:
Engine Load = 43.529 %
Engine Coolant Temperature = 69 °C
Fuel Trim Bank 1 Short Term = -0.781 %
Fuel Trim Bank 1 Long Term = -0.781 %
Engine RPM = 2,574 rpm
Speed (OBD) = 107 km/h
Timing Advance = 27.5 °
Intake Air Temperature = 9 °C
Mass Air Flow Rate = 27.44 g/s
Throttle Position(Manifold) = 21.176 %
End of report.
I read the Rosstech info for P2181 and it says
Thanks
End of report.
I suspect the thermostat. I read a good writeup on this board on how to replace the thermostat but for me it seems kind of daunting. Although if it comes down to that I'll do it. What I am wondering is if there is any other component I should check or more diagnostics I should do before attempting to replace the thermostat. Also what's the normal coolant temp for a Passat? My car is a 2003 Volkswagen Passat 1.8T AWM.Freeze Frame data stored with in the 68*C ~ 80*C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
Thanks
