Noticed a crimped 1/8 inch or so diameter vacuum line that runs from the top of the intake to the bottom of the intake behind the driver's side headlight on my 1.8 turbo. I think it may be causing the P1128 code. Does anyone know about this vacuum line? I also need the model # so I can replace it. Thanks in advance.
I am guessing you have a right hand drive Passat as a USA spec 1.8T does not have a vacuum line behind the driver's side headlight. If not, take a picture and add your location to your profile.
That would be the vacuum line to your diverter valve. You just need a long enough section of vacuum hose to replace it. About a 5' section of 3.5mm ID hose should work.
can anyone help with info. regarding attaching a photo
When I click on the small Icon to attach a photo it asks me for a URL address...what is a url address to a photo? This oone person seems to have the answer of a suspect vacuum line and I want to send him a photo of my engine. Thanks-Rob
