1 - 3 of 3 Posts
Got a Emissions workshop twice yesterday but none today. I pulled codes and here is what i got.
1 Fault Found:
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
I am going to try cleaning the Air sensor tomorrow after getting some cleaner.
Since it is a Multiplicative error, you are likely correct about it being an MAF problem. Mine (2001 AUG) was replaced under warranty at about 63k miles.
Zero errors are more likely to be a vacuum leak. If you have the original crappy hoses, they need to be replaced. I had two go bad and give lean errors. Also the "L" hose got a hole in it, and that 3-legged hose as the back of the valve cover.
1 - 3 of 3 Posts
