As you know, P0010 is a fault for the Cam position actuator.....or engine timing solenoid....it controls the amount of timing advance and retard.....it could be as simple as a bad electrical connection, or a bad solenoid. it could also be a loose cam chain with a failing cam chain tensioner...but you would hear noises coming from the cam chain cover if that were the case. ( Our timing issues started with a bad cam follower on the HPFP and caused damage to the N275 valve, exhaust cam timing module, cam cover, ect, ect....but we were ignorant and let the problem go too long as we were busy tracing codes and replacing sensors, etc)
Your timing chain has probably not bitten you yet...you would have heard that!...the car would also probably not crank at all as pistons would have hit valves, ect....(but did the wife hear anything out of the ordinary on the way home?)
maybe start with the obvious: fuses. then the wiring at the solenoid, ect. decide if you want to splurge and replace the solenoid. then check your HPFP cam follower for wear..while you are in there, you can peek in and take a look at the intake cam lobe and chain.
I can tell you this....the whole timing system is dependent on oil pressure to work well. I have even cleaned out our N275 valve with improved idle results...do change the oil if you have not done so in a while as preventive care.
Not sure about the waste gate issue....but I did read somewhere that it affects how much fuel is sent to the motor?....totally not sure about that..who can confirm?!?!?!
