Passat 1.8T 2000. I have several tubes, covers, a heat shield laying on the ground right now trying to get to something I can clean. I was dumb and was trying to paint my front grill badge with the grill still on. Even though I taped everything up and stuffed the holes in between the badge itself, I was running late and started it while it was still wet, I later learned my spray can was defective and wasn't spraying out a mist but spraying out thicker drops and it was running). Anyways I started the car and it immediately choked and the engine shut off. I started it again and gave it gas and it passed and I was able to drive it all night making deliveries. Next day, today, it has this really rough idle, more rough the lower the RPMs. The engine light is blinking on and off and according to the manual that means power restrictions as a precaution so I don't eff it up any further.
Now to the part referenced by the title, as I was digging theres this air tube that is completely degraded. Will post pictures after this post. The location is right side of the engine, lower than the coolant resivoir, below the (aluminum?) air intake. It has a bunch of oil crust and rubber crumbs and the angle it down towards the engine so I can only imagine where the choke point is that I'm trying to clean that. Not only that I don't have time to order in a new part so hopefully the stealership has one or I can yank one off from a junkyard car.
Codes:
P0102 lack of airflow something something
P1128 missing definition for something
P0301 cylinder 1 misfire - I replaced all of the spark plugs with copper ones 2000 miles ago. I opened up all of them today and they again have oil in them.
MAF I think is good. 02 Sensors I think one of both are done. 14 mpg right now city driving. 19 mpg highway.
Codes:
