Yeah no problem. I just removed mine today and what I pain they are to get out. Getting the vents out of the dash is relatively easy and don't worry, you can't wreck the dash unless you are really cranking super-hard. The hard part is getting the stupid bulb out of the holder.
Since there are no pics on the write-up anymore, let me see if I can describe what you need to do to pull the bulb.
1. Get the vent out and disconnect the electrical connector (pulls straight out with force)
2. Hold vent in your hand so you are looking down on the empty electrical connector socket (should see 2 little pins down in socket)
3. Notice on one side between the amber light pipe and the black bulb socket you will see a very slight semi-circular dimple/cutout, this is the slot where you have to insert a "key" to unlock the bulb. I tried several items but ended up using something very strange. I was digging around my shop and stumbled across my old OEM windshield wipers. Each blade has 2 thin metal strips that are about .5mm thick, 2mm wide and the whole length of the wiper. I removed one of these strips and stuck that down in the semi-circular dimple (so it would be traveling along side the black bulb socket down into the vent assembly) until it wouldn't go any further (about 1 inch). Then grab some needle-nose pliers and pull the bulb out. Do NOT remove the "key" until bulb is all the way out or bulb will get stuck again. That's it! To reinstall, simply push the bulb in w/o using the key
Like I said, I tried several things as keys and ended up using a very thin/small piece of metal. Hard plastic like the write-up suggests would also work but it must be very hard. I tried using a zip-tie the first time and it was too flimsy.
Anyways, good luck and hope this helps. If you get stuck, send me a PM and I'll get you some pics of how it looks.
Laters,
-Chris
