I'm certain this topic has been beaten to death on this board. But here goes again:
-My owners manual ('04 1.8T) says the car was filled at the factory with 5W40 oil. It also says you can "top off" with 5W30. But the manual is clear - for oil changes, only use 5W40. It also says you can use a synthetic oil.
If one reads 'between the lines", this suggests that VW does not use synthetic oil for the factory fill. When I purchased the car, I asked the service manager at the dealer what they used. He kind of "mumbled" and said: "synthetic blend".
From other threads on this board (and at bobistheoilguy.com) I've concluded that with this turbo engine, I should use full synthetic.
Do you all concur with this (that factory is "dino" 5W40" and that you should use full synthetic 5W40?
