1 - 3 of 3 Posts
I believe mine is leaking. It bolts on the side of the engine. Part # is 06H103464L. Does anyone have service manual instructions on how to replace this? Are there service manuals on here?
It looks pretty straight forward, but there are things in the way and I don't want to start taking things apart without some instructions and have everything on hand that I need.
Thanks
Ed
Yes, I found the bolt tightening sequence, But, there is a hose or 2 in front of the separator that I don't know if I have to remove also. They look like they are connected to the radiator, so if I remove them will I need to have coolant on hand to refill with? Or, should I just drain the radiator?
Should I drain the oil also? I know these sound like minor questions, but I am just a weekend DIY and want to have it spelled out step by step
1 - 3 of 3 Posts
