I was driving on the highway this weekend and felt an odd wobbling in the car. I had been driving for about 15 miles at the time. Minutes later the oil pressure warning with a STOP CAR on the screen came on. I opened the hood and there was some light smoke coming from the passenger side of the engine, maybe oil dripping on the cat? Anyway, I checked the oil level and it was below threshold. Luckily, I had some oil in the trunk and filled it up. The wobbling was also gone and I drove around 20 miles. The warning didn't come again that day.
Next day, I go grocery shopping and on the way home, after just 3 miles of driving, the oil pressure warning comes on again. This time without any wobbling or smoke from the car. I check the oil level and it's still filled up all the way. I was just one mile from home so I decided to go for it and drove the car home, praying I wouldn't break anything.
Today I took a look at the car: The oil level is still all the way up, so there is no major leak. The oil looks a bit dark, but not terrible I guess. It has been changed about one year ago (~5000 miles). Previous owner told me he always used synthetic oil and so have I since I bought the car 4 years ago.
The oil filler cap looks okay, so I guess there is no oil sludge issue?
I noticed the oil pressure sensor is covered in oil but so is almost everything in my engine room, I have never cleaned it and it was there since I got the car. I also saw that the wire shielding is retracted from the adapter. Could the sensor or the wiring be the problem or do you suspect something more sinister?
I am thinking of doing the following:
I want to install an oil pressure gauge following 2001.5 AWM Autometer Oil Pressure Gauge Install and Installing an Oil Pressure Gauge
If the oil pressure is fine, I will probably have to switch out the sensor, if not, I wouldn't know what to do next.
Instead of installing an oil pressure gauage, I also read somewhere that I could just run the engine for a bit or drive around for ~10 miles and then check whether I have oil coming up under the oil filler cap.
Any opinions or advice? As always, thanks a lot for helping a car noob as me.
