1 - 2 of 2 Posts
I had an oil leak via a cracked sump. Only knew this when the oil light on the dash came on. I have since changed the sump, the oil and the filter and also put in a new oil level sensor in the sump. However, the yellow oil can symbol light still remains on and when the car is first started - CHECK OIL LEVEL note with one longish beep comes up on the dash before extinguishing.
Any ideas please anyone as to what may be wrong? The pressure sensor which is in the filter housing does not read low. W reg on a UK plate.
Have done a search but no solutions were offered.
Discussion Starter #2
Ok thanks for the assistance - sorted it out by disconnecting the battery and reconnecting after about a minute.
1 - 2 of 2 Posts
