1 - 7 of 7 Posts
Hi Guys
I hope I find everyone well. When I was changing my left hand tyre this morning I noticed some oil leak as indicated on the attached picture. It seems this leak has been going on for some time. All along I used to get a burning oil smells when I ever I was driving and a few drops on the garage floor. I put my hand at the back of the valve cover and I suspect that's where the oil leak is coming from. I have take a picture also as attached. If its leaking from this place(forgive me I don't have clue what's its called)is it something that I will be able to repair myself? 0r probably this leak could be coming from somewhere at the back of the engine?
This is the place where I am suspecting oil to be leaking from.
I
Automotive tire Tire Rim Alloy wheel Bicycle part
Automotive tire Hood Wood Automotive exterior Bumper
Automotive tire Hood Motor vehicle Grille Vehicle
That black disc is called a camshaft sealing plug. I just changed mine due to a similar leak. Mine had visible oil smoke rising up off the exhaust manifold. You have much more oil leaking than I did, sdo it might be coming from somewhere else. To check if your leak is coming from that plug, there will be a drop of oil at the lower edge that you will be able to get to with a finger. If you can get your Passat up off the ground, you will be able to look up at the exhaust and see if oil is , indeed, leaking onto it.
Hi Buddy
I have managed to put my finger at the edge of that plug and it came out wet. I have also looked at the exhaust manifold it seems they oil leaking onto it which explains the foul smell.
My car is a right hand drive so does it have these seal plug on both sides? and on a scale of 1-5 how would you rate the difficult in changing these plugs?
Thank you kindly.
Hi Buddy
Thank you kindly.
Yes, the V6 has these plugs on both banks. They are easy to change, especially your left-hand side. However, with the amount of oil leaking, I suspect the valve cover might also be leaking.
Anyway, to change them you need a long flat-blade screwdriver, hammer, and I use some double-sided sticky tape to keep it stuck to my index finger while I guide it into place. My old one had some black RTV on it, so I put some on the new one.
There are some Youtube videos showing the entire process, but it is rather straight-forward.
Discussion Starter · #6 ·
Thank you so much. I will give it go this weekend.
1 - 7 of 7 Posts
