1 - 9 of 9 Posts
i've read that the ohm rating in the front speakers are diff than the rear. is this true? if so which is which and what is what?
depends on what sound system you have as standard OEM.
if you have W8, you probably have a monsoon?
all the speakers are 4 ohms except the rear mid/subs. those are 2 ohms. not a big deal for a hu swap though since the load is on the monsoon amp and not the HU.
my HU says to only use speakers that are 4ohms each. maybe that's why i have to push the fade back to the rears just to get them more juice.
Actually, the reason you have to fade to the rears is because you have no midrange back there. The "mid" is really a sub and doesn't play much more than 400Hz or so and then you have a tweeter playing from 2.5KHz or so and up. Kind of a big gap but it serves 2 purposes. 1) you have som decent bass in a stock car and 2) it keeps all the sound in front of you which is where it should be.
Kitmobley, I ended up switching the stock Monsoon speakers to JLAudio XR650Csi's with a CleanSweep DSP. This dramatically improved the sound in my W8 Passat and improved the mid-range even with the Monsoon Amp!
Discussion Starter · #9 ·
oh yeah. thanks for the TIP!
1 - 9 of 9 Posts
