1 - 2 of 2 Posts
OK so I have a 2000 passat when all my doors are closed my odometer says lit up ... now my trunk latch is broken could this be causing it to stay on ? That's the only thing I can think of let me.me.know your opinions trunk will mother latch so mechanism needs replacing!!
The backlight? Or, just the numbers?
If the backlight (and, it's ONLY the odometer backlight; all other cluster backlights turn off/on correctly): internal fault in cluster.
If your complaint is just that the numbers are always visible: Normal operation. Move along, nothing to see here.
1 - 2 of 2 Posts
