1 - 2 of 2 Posts
Its time to let it go, bought new car.
Has:
-Satin Silver with gray cloth interior
-Vag sideskirts
-Oettinger front grill
-front lower spoiler
-Rear trunk Oettinger spoiler and lower valance
-Tower stress bar
-VDO turbo gauge on A-pillar
-Aluminum cluster rings
-17 'turbo look' rims (like VW CC)
-K & N Air filter
-Wettenauer chip on ECU, holds 11psi, spikes @13
-Silicone vacuum lines
-007 valve
-Halo HID lights
-Timing belt done at 145K
-Tranny oil changed at 145K
-2 new axles front replaced at 163K
-Lowered with Eibach springs (1" drop) and Bilstein black shocks at 155K
-Stop tech cross drilled and slotted brakes front and back, with pozi pads
-Turbo replaced at 130K
-Fenderliner cooling fabricated by me. There was a write up too on passatworld.com
-Original owner
-paint is glossy, kept most of the time in a garage, but has some dings from rocks on highways. no Accidents !
NEEDS:
-ABS sensor
-Sunroof switch
-2 rims need to be straightened, they are fixable, I checked, no cracks.
-Tires are 50% thread left
-Has check engine light on, for key switch ignition
-Turbo burns 1qt every 1000 miles.
-Interior is grey cloth, needs door inserts TLC, and headliner TLC
If you need photos, email me at [email protected]. Or check my profile, if photos exist...Im member here since 2003.
1 - 2 of 2 Posts
