Bit slow on here today isn't it :thumbup: :b5:
Would an exhaust really give that much hp gain, would the ecu compensate for this gain without the engine running lean or is that in conjunction with a proper rolling road chip tune to set up the fueling and boost??scotty_passat said:surging has never been a problem on AEB motors. Biggest "surger" was the AWW motor in the golf/jetta when the tuning first came out (all chip vendors had problems), and even those motor codes have been revised for smooth operation.
exhaust will add ~10-15 hp.
UPsolute can be installed locally which would be a big plus given you're not in the US. Might also be the only option as the US-guys might not have tuning for your Euro ECU code.
ECU should adapt ok to exhaust. if you dyno it, get an A/F plot to be sure. UPsolute can create a custom file for you if needed for an extra fee.PSM20VT said:Would an exhaust really give that much hp gain, would the ecu compensate for this gain without the engine running lean or is that in conjunction with a proper rolling road chip tune to set up the fueling and boost??scotty_passat said:surging has never been a problem on AEB motors. Biggest "surger" was the AWW motor in the golf/jetta when the tuning first came out (all chip vendors had problems), and even those motor codes have been revised for smooth operation.
The local 'Upsolute' dealer (20 miles away) will come out to me to do the upgrade, all in for £305 ($549) and can supply me with a 'Forge DV' for £90 ($162), just have to fit it myself.
Not sure about the details of the TT exhaust, I'm sure it had a cat installed.PSM20VT said:Is the techtronics exhaust expensive and loud to give those sort of gains and did it have the cat removed ?
I only asked about the fueling with an exhaust as i know alot of Subaru's have mega problems if they fit hi flo exhausts without getting them set up on a dyno.
