1 - 2 of 2 Posts
I bought a 2000 glx 2.8 4motion. It had a blown motor,got a newer one with 100k went to turn over but no fuel. Checked it out we have no power to the fuse for fuel pump. Wiring problem right? Any help what to do is greatly apreciated.
PassatWorld Elder
Check the relay under the dash. It has 3 relays inside. Mine would run the pump, but not fuse 34. Multiple issues came with that. If you supply power to the pump directly, does the car run?
1 - 2 of 2 Posts
