did you check your fuses?
if you want to check for spark, go buy yourself an ignition spark tester tool. it's a little spark plug looking thing that clips to metal on the engine that you plug into the spark plug socket/wire.I checked all the fuses, but the only one that was out ended up being my cigarette lighter.
Is there any relays I should check?
Should I pull the plugs to check for spark?
What should i do to check the fuel pump since its silent?
if that doesn't fix it, take a look at your crank position sensor. if that goes dead the car does not fire ignition.I am in a similar situation (01 GLX 4mo) everything is as usual when I cranked, but there was no engine turnover, took it to a shop and they said it is my ignition coil. Ordering the part and DIY'n it because they want $480 to do it, and hoping this alleviates the issue.
