I'm trying to diagnose an issue I'm having with my 2013 Passat TDI SEL with the RNS-510 head unit. All of a sudden last week, I lost all sound to the speakers. No radio, no Bluetooth phone, no NAV sounds, chimes, etc...
I've tried various things, including a reset of the head unit (holding down the 3 buttons on top), disconnecting the battery for a few hours, etc...
I'm thinking the issue is that the amplifier has failed, or the fuse protecting the amp has blown. The problem is, all of the diagrams I've found online for my model don't look like the fuse box under the hood) where the fuse for an amp would be located).
I've disconnected the amp itself to tried to test for power with a multimeter at the wiring harness it attaches to, but the holes on it are too small for my leads to get in there and I'm not sure which of the dozens of holes on the adapter I'd need to test anyway since most are speaker wires, not the power from the battery. I've tests the fuses (with a multimeter) in the engine compartment and side of the dashboard just to be thorough, even though they're not for the amp, I simply can't find why I'm not getting sound.
Attached are pics of my fuse box under the hood, a diagram I found online of what a B7's fuse box should look like, my factory amp, and (installed), and the front and back of my amp removed.
Thoughts?
Thoughts?
