I'd suggest you reset the errors (hold ECON 2+ seconds after the error codes all display after a test cycle). That might work.
A little background:
The dampers are just a 12VDC motor and a potentiometer for position feedback (0-5 VDC). The wires all go to the head unit. Relays internal to the head unit apply 12VDC of the necessary polarity to position the damper where it's needed.
Since the dampers do move to defrost and floor during the self test, you know the damper motors work. The problem might be the damper position feedback potentiometer, or maybe the head unit is just confused. You can monitor the damper position, e.g. channel 35 for the footwell/defrost damper.
That said, the lack of any action when you press Defrost makes me wonder about the head unit... Sorry I can't be more definite.
