1 - 3 of 3 Posts
220000km 1.8t manual normally runs great, took on a road trip, on my way home, 5th gear cruise control, engine lost power and i pulled over, came to the conclusion its the fuel pump, got power and would turn over and sputter a bit then stop. got it towed home, now it will not turn over at all, i can manually crank over the starter by reaching underneath, I replaced the ignition switch and im still not getting any cranking
Discussion Starter #2
figured it out, the number 12 relay was not clipped in all the way, maybe previous owner or somthing was mucking with them, i bought this car off a younger kid for pretty cheap, its pretty modified, so through the whole thing i got to clean up alot of wireing mess
I had similar results when the MAS airflow sensor failed. Just lost power and sporadic starts. Replaced and instantly healthy
1 - 3 of 3 Posts
