I have seen numerous threads on this issue so I apologize if this is redundant!
2000 passat replaced the window regulator on driver door. it works great with the key, all windows and locks work
but the starter is now locked out, the windows, sunroof and trunk do not work at the door switches. http://www.passatworld.com/smilies/banghead.gif
So, It appears to be a CCM wiring related issue. I pulled the CCM and all the wires look like new. My guess is that in replacing the window reg, I damaged a wire. My question, am I on the right track? My reasoning is that I have to completely open up the harness to find the bad connection and that it is somewhere from the door to the CCM. Just want to verify that im on the right track as wringing out 50 tiny wires is going to be quite a task.
Anyone with a good suggestion will get Karma points, thanks for your patience http://www.passatworld.com/smilies/confusedd.gif
