So it looks like the Passat may not make it to 500K afterall.
This car has 475,000 KM on it and the crankshaft seal went, oil everywhere. I thought this would be a simple fix but things escalated pretty quickly.
After replacing the seal I had to retime the engine because I made the mistake of not putting the crank in TDC. Once everything was buttoned up I tested the compression and one side was zero in all 3 cylinders.
When I removed the valve cover from the one side, I noticed that the camshaft tensioner was missing the plastic guides. It looks like the chain had been grinding into the metal of the tensioner for some time. I pulled out the cams, bought new plastic pads that I fit on the tensioner and put everything back. I lined up the arrows according to the book, timed the engine once again and yet still no compression.
My guess is that before I pulled off the valve cover when adjusting the cam on the one side to align it with the other, the chain jumped because the guides were broken, throwing the cams out. Cranking the engine several times may have bent the valves.
I can't think of any other reason why there is no compression now.
What would you guys do? Is it worth fixing this engine with 475,000 km on it or should I just scrap the car? The body and interior is in such great shape. Would hate to see 'er go.
