I finished painting up the timing chain cover I was working on last month. Just to update you guy's, I actually cracked the first one!
. Bought another one from the same guy in CO so the total costs of both is $70. Here's the finished product:
This is the same silver engine paint I used on some other parts. Once the water pump and HB are installed, you won't see much of this cover anyhow.
I then bought a valve spring compressor tools and began disassembling the valves from the heads. I lapped 6 valves this evening so far; here are the pics:
NOTICE the carbon on the edge of each valve...:
AFTER lapping the valves:
Should be finsihed with both cylinder heads by the end of the week.
