1 - 17 of 17 Posts
acquired from owner of ukpassats yesterday of his black KO4 beast that he is selling
his car
washed and a good rubbin down first
primered
first coat
lacquered
finished
Did they mount the turbo in a different spot on UK models because of the RHD. It looks like you dont have a turbo hanging. Or does it just not have a turbo at all.
mine is not a turbo mine is a 1.8 20V non turbo 125 bhp. and the filter is a K&N 57i induction kit
Yeah the intake manifold looks totally different. Shows how Newb I am, I never knew they had a non turbo 1.8L.....
i need one of those covers....mine was missing when i bought it :confused:
Early models didn't come with one (my new '98 in the US came without) but I am not sure when they started appearing.
Discussion Starter · #10 ·
think this is a b5.5 cover modified to fit the b5. it does have battery cover just wasnt dry when i took the last pic
What's funny is that the B6 A4 still doesn't have the full cover. Just over the right and left sides (read: 2 separate pieces), but not over the battery. The engine bay on my 2004 1.8t passat looks better than my wife's 2004 A4 1.8T engine bay.
Any reason you didn't paint the engine cover to match while you were at it?
did you sand the cover down before priming? I been wanting to paint my plastic engine parts, just tryin to figure out how to do it...
painted my engine cover and few other plastic pieces:
1) cleaned with soap and water
2) sanded down slightly (400 grit)
3) sprayed with 3 coats of surface adhesion promoter
4) applied a high temp base coat (3 coats)
5) applied paint (3 coats)
6) dried overnight
7) applied clear coat
Discussion Starter · #16 ·
i gave it a good scrub with soapy water, gave it a rub down with 800 paper then 2 coats of primer, rubbed down again with 1200 paper then 2 more coats of primer, then 3 coats of colour and i think 3 coats of lacquer
1 - 17 of 17 Posts
