1 - 3 of 3 Posts
Vendor
Hi everybody!
I proudly inform you that we offer some new VW Passat parts and accessories, such as
1) DBA® - Street Series™ XGold Drilled and Slotted Front Rotor - 2010 Volkswagen Passat DBA Street Series XGold Rotors
XGold Slotted and Drilled 1-piece front rotors are designed for high-speed performance street driving. Rotor slots and cross-drilled holes resist heat buildup and provide grip that stays the whole night. 144 pillars between rotor faces provide faster cooling and greater strength to reduce heat warpage and extend life. Sized to exact OEM dimensions for easy, bolt-on replacement without modification.
2) Energy Suspension® - Hyper-Flex™ System Master Set
Features:
- Made of Hyper-Flex™ performance polyurethane
- Resistant to under vehicle fluids such as: oils, coolants, road contaminants, etc.
- Replaces the original, short lived and typically too soft rubber mounts and outdate
- Soft enough to absorb vibrations for street use yet rugged for racing use
3) Cipher® - CPA2001 Euro Series Racing Seats
Features:
- Higher bolsters and deeper upper body support
- Engineered to work properly with 4- or 5-point racing harness
- Keeps your body in the optimum position to make inputs to the car
- Reduces driver workload
- Lowers lap times
- Typically half the weight of a stock seat
- Sold in pairs
4) KW Suspensions® - Volkswagen Passat 2009-2010 Hydraulic Lift System
Features:
- Allows cars with low ground clearance to clear obstacles more easily
- Complete kit including KW coilover kit or conversion kit available
- Can be activated from inside the vehicle via a LED position control switch or by an optional remote
- Can be activated while driving (up to 50 mph)
1 - 3 of 3 Posts
