21 - 28 of 28 Posts
I have a 2012 Passat tdi with bank one sensor one issues. Can anyone point me in the direction of where to look for help?
Any help would be appreciated. Thanks in advance Ronnie
I know what an o2 sensor is. Not sure about the dieselgate lol. My codes not for an 02 though. Why you suspect that?
Your code is for a oxygen sensor since you said your code was "bank 1 sensor 1" ...sensor means oxygen sensor for your vw. 1800hp gas car isn't close to a diesel vw so you can't compare the two at all. Search dieselgate and you'll know what it is. Hope you fix your car
Discussion Starter · #22 ·
Sensor one bank one from everything I’ve researched is egt sensor in the manifold
Okay didn't see that. Well that code differs from my b1s1 code I had. Call your VW and dealer and have them check the VIN number to see when or if the dieselgate warranty is active or expired. If it's still covered it should cover it...dieselgate covers anything emissions related from sensors to turbo. Worth a shot and saves you money
21 - 28 of 28 Posts
