1 - 20 of 52 Posts
obviously a V6 , sounds like you have lost a CCT guide shoe(s), , cannot tell which "bank" it is on. You need to address this ASAP before something catastrophic possibly happens. Is your CEL on?
I'm also suspect of the CCT, that sure sounds noisier than normal.
Sounds like it's not getting much oil to the head, or VERY thin oil.
What's it look like down inside the oil fill hole on the valve cover and underside of the oil fill cap? Dark burned deposits?
I wouldn't be revving that engine or driving any more for that matter until you crack open that valve cover to investigate.
Or cam chain tensioner assembly?
98121
You know that infamous tensioner? Mine is still stock.
That's what I was referring to, the CCT.
Is that a picture of YOUR car?
It's due for its oil change now. I was going to do it as well as a whole bunch of other goodies I just got from ECS.
I just installed a new expansion tank and heard it while burping the coolant.
I just never heard that noise before. It seems to make a noise under no load, just revving. No noise at idle.
I'm still in the same camp, pull that valve cover off and investigate that CCT for missing, broken or severely worn plastic shoes (top and bottom) and also check to make sure the cam chain is not slack. If there is any slop in the cam chain the CCT is partially collapsed.
Now I even suspect this even more because of you mentioning pinging. I personally have never heard a Passat engine pinging unless something was seriously wrong.
Discussion Starter #12
Yeah, I was going to post "Is the ignition timing adjustable" here but had too many red faces so far. Post back tomorrow.
Worn CCT shoes will have notches cut into them from the sides of the cam chain.
Usually they get cut up or worn so badly the get very thin and brittle and break apart, working there way into the bottom end of the engine, getting sucked up into the oil pick-up screen and starving the engine of oil.
Discussion Starter #15
Great! Guess he will be sitting for a few.
Timing is NOT adjustable or at least in the way you are referring to.
The timing has static adjustability, but that is ONLY for when you change the timing belt, timing chain or CCT.
Have you checked to see that something hasn't come loose and it bumping up against something or loose and just rattling?
Discussion Starter #19
Nope. Nothing loose. If it was a bearing, it would make a noise all the time correct?
because the exhaust cams are always positively driven by the timing belt and thus timing chain sprocket also, when you hit the gas (rev engine) ,chain slack is removed from the top of the chain's path by the CCT upper piston moving up to advance intake cams timing, when revs are "backed" off chain has slack and is "slapping" valve cover. (noise) Believe upon inspection you will see the plastic guide shoe is gone.
1 - 20 of 52 Posts
